Leaking petcock
  • Jershsmersh
  • Jershsmersh's Avatar Topic Author
Leaking petcock
21 Apr 2014 16:16
#629889
I recently picked up an 82 kz750N1 for a steal. Of course it's had some issues along the way that I've worked out. The issue I'm having now is a leaking petcock. The vacuum control is not shutting off the fuel flow so I'm getting puddles of fuel not to mention flooded crank case. I don't want to buy a petcock rebuild kit because it will just happen again down the road. In the meantime I've put an inline shutoff valve on the fuel line but this is a temporary fix. What I need is a manual petcock, does anyone know of any aftermarket or perhaps oem petcocks from other bikes that will fit?
  • nickleo373
  • nickleo373's Avatar
Re: Leaking petcock
21 Apr 2014 16:55
#629890
It's probably just a bad diaphragm in the old petcock. Check the crankcase for gasoline in your oil before starting the bike again
1981 KZ550C LTD
"If you ain't first, you're last"
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Leaking petcock
21 Apr 2014 17:47
#629895
I would just rebuild the petcock. If done correctly it will last for many years.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • martin_csr
  • martin_csr's Avatar
Re: Leaking petcock
22 Apr 2014 06:23 - 22 Apr 2014 06:23
#629945
If the bolt-hole spacing on your Spectre is 34mm,
here's a fuel valve topic with some options: KZR topic - Manual fuel valve option
Last edit: 22 Apr 2014 06:23 by martin_csr.
