29mm smoothbore for 76 kz 900
- NHenneous
20 Apr 2014 15:51
Im looking for a set 29mm smoothbore carbs for my 76 kz 900 any ideas where I could get a set or point me in the right direction would be greatly appreciated. Thanks in advance. Nathan
NHenneous
Re: 29mm smoothbore for 76 kz 900
20 Apr 2014 16:03 - 20 Apr 2014 16:04
There is only one set currently but ebay is typically a good source. This thread should help you learn what to look for when it comes to the slides and such...
www.kzrider.com/forum/3-carburetor/208131-29mm-smoothbore-setup
Last edit: 20 Apr 2014 16:04 by Nessism.
- NHenneous
20 Apr 2014 17:31
Nessism are you talking about the keihin carbs. If so which are the better carb keihin or mikuni. Thanks for your time.
NHenneous
20 Apr 2014 18:10NHenneous wrote: Nessism are you talking about the keihin carbs. If so which are the better carb keihin or mikuni. Thanks for your time.
"Smoothbore's" are Mikuni's. VM29's. They were very popular back in the day. I'm not a modding guru so can't comment on all the various carbs on the market, but if making the move to some newer carbs I'd go for RS Mikuni's. 34's maybe for a relatively stock bike. Larger for modded bikes but again, I'm not the best source of info on such matters.
- NHenneous
20 Apr 2014 18:21
Ok thank you for your time and input.
NHenneous
