Help me ID these carbs and exhaust?
  • Killman
  • Killman's Avatar Topic Author
  • Now with 99% more ducks
16 Apr 2014 20:37
#629367
Like the title says, I could use a hand identifying these carbs., and the exhaust. Both are on an '81 KZ750Ltd, The exhaust is a left-hanger. The carbs are Mikunis, I want to order some new bolts for them and want to make sure I order the right set, (I know that I could take the crappy old ones and match them, but I'd rather just order a new set). The exhaust I'm just curious about.
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
1983 kz440 ltd
Quack
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Help me ID these carbs and exhaust?
17 Apr 2014 00:31
#629377
Are you sure the carbs are Mikuni carbs? I do not see the name in any of the pics you posted. IIRC the stock carbs used on the 81 kz750 LTD or H2 model were a set of Keihin CV34 carbs. which to me is what the carbs in the pic look like.
I did notice that one of the pods (appears to be on carb#4) has a rip in it where it meets the carb. It would appear you need to replace it. If the others look the same they all need to be replaced.
As to your exhaust system, I can not tell from the 3 pics you posted. Will say it looks somewhat like the one I have on my 650 and it is a Denco. Note I am not saying that is what you have only that I do see some things that look the same. Can you post a better side viiew of the entire bike?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Nebr_Rex
  • Nebr_Rex's Avatar
17 Apr 2014 03:53
#629383
BS34 Mikuni
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Killman
17 Apr 2014 11:16
#629416
That's hilarious Nebr, answered on both sites :laugh:
Thanks Nebr, that's what they seemed to be from the research I had done. Off of a GPZ model?
What would have been the advantage of making that swap? They're still CV carbs, correct? So even if I replaced those busted up pod filters with some K&N's, they could give me some throttle response issues, unless the PO's actually jetted right for the new configuration with the 4 into 1 as well?
I am not the guru, just trying to understand what I'm working with.
Thank you.
1983 kz440 ltd
Quack
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
17 Apr 2014 11:44
#629417
Mikuni BS 32
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
