Best port for petcock - '77 650B1
- GPz11
15 Apr 2014 16:58 - 15 Apr 2014 16:59
Folks,
I've had to replace the stock manual petcock with a vacuum one. I just checked my carbs and they don't have the port for the petcock.
Can I just run a line from one of the sync ports?
Thanks!
Thanks!
'77 KZ650B project
Last edit: 15 Apr 2014 16:59 by GPz11.
Re: Best port for petcock - '77 650B1
15 Apr 2014 17:58
Yes, that should work. It shouldn't matter which carb you chose because assuming the carbs are sync'ed all 4 vacuum ports will be pulling the same level of vacuum. Ed
- GPz11
15 Apr 2014 18:00
Cool, Thanks, I figured it'd be fine but I thought I'd double check.
'77 KZ650B project
- Twist1
21 Apr 2014 15:06
I would tie all four together-you need full vacuum to operate the petcock-Good Luck
Bikes I own,76 KZ 750 Twin-79KZ750 Twin (6700 actual miles)-83 KZ 750 K1 belt drive chopper
- H1Vindicator
21 Apr 2014 15:15
The stock setup is one vacuum port for the petcock.... one is all you need.
A typical problem w the vacuum petcocks is diaphragm failure or a diaphragm o-ring that needs replacing or doesn't seat properly.
