breather or plug
  • bobbisman
  • bobbisman's Avatar Topic Author
breather or plug
11 Apr 2014 11:28
#628700
78 kz650b. Just about done rebuilding the carbs and some pictures are showing 2 vent lines coming off the carb bodies. Mine had 2 rubber plugs instead. Does it make a difference? Vm24's. Thanks
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: breather or plug
11 Apr 2014 13:50
#628707
I guess it depends upon which ports you are talking about. If they are the bowl vent ports then they need to be open to the atmosphere or the carbs will not work correctly. They provide atmospheric pressure on the fuel in the bowls, which is what allows the fuel to be pulled up via the jets in the carb. Here is a pic of the connections on the vm24ss carbs. This set has the vent ports on #2 and #4 and it also has a vacuum port to attache to a vacuum petcock on #2.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • bobbisman
04 May 2014 15:34
#631309
It's is the vent ports on the #2 and #4 carbs but instead of having a vent hose, they both have plugs. Exactly like these:http://www.z1enterprises.com/ItemDetails.aspx?itemDescription=Carb+Holders+%285%29+Vacuum+plugs&item=KL11-4972. I'm assuming I should be using hoses and not plugs. I'm just confused as to why it ran with them plugged. Or does it not make a difference?
04 May 2014 15:37
#631310
It does make a difference. Unplug them and install tubes that run toward the rear of the bike. Mine terminate at the air box cap. Ed
  • bobbisman
04 May 2014 16:15
#631316
Any reason they would have been there to begin with? The guy I bought the bike from had a bunch of stuff Jerry rigged. I'm just wondering if this is something he may have done to rectify a different carb issue
