Where to buy VM24 mains and pilots?
  • Tumbleweeds
  • Tumbleweeds's Avatar Topic Author
09 Apr 2014 10:06
#628421
I have pods and full stock exhaust right now. Seems I have 97.5 printed on my hex jet (main) and 15 printed on my pilot. Bike still wants to rev higher when full warm and choke is applied. I think I need a bigger pilot for sure, and want to order a couple mains just to have for when I get my 4-1.
Other than the idle the bike runs decent, but when accelerating, backing off the throttle a little bit is actually faster than more throttle. I think it is just starved for fuel. Needle is stock, one slot up from the bottom.
Anyway, I'm having a hard time finding these hex jets. Anyone have links to where i can buy VM pilots and mains?
On the hunt...
4/2/14-1977 KZ650 B1 17k miles
  • martin_csr
  • martin_csr's Avatar
Re: Where to buy VM24 mains and pilots?
09 Apr 2014 10:33
#628424
Z1Enterprises.com has them (K&L). K&L parts are made in Japan & OEM quality.
  • Tumbleweeds
09 Apr 2014 11:29
#628430
I looked on z1, but I can only find the round style mains.
On the hunt...
  • nickleo373
  • nickleo373's Avatar
09 Apr 2014 11:36
#628431
Did you try jetsrus.com?
1981 KZ550C LTD
"If you ain't first, you're last"
The following user(s) said Thank You: Tumbleweeds
  • martin_csr
09 Apr 2014 14:59 - 09 Apr 2014 15:00
#628451
Tumbleweeds wrote: I looked on z1, but I can only find the round style mains.
I'm pretty sure the VM24 carbs use the large round main jets. On my 81 650-CSR the bleeder pipes that they screw into are hexagonal in shape, but the main jets are round. If unsure, contact Z1Ent... they're good about answering questions.
Last edit: 09 Apr 2014 15:00 by martin_csr.
  • zukdave
  • zukdave's Avatar
09 Apr 2014 16:22
#628456
The hex part is the needle jet that the main screw's in to.
Call Rob at Z1 he'll hook you up with everything you need.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • martin_csr
10 Apr 2014 06:07 - 10 Apr 2014 06:11
#628534
The hex part is the bleeder pipe. Aren't the needle jets pressed into the carburetor body? ... it's been a while since mine were apart. :blush:
Last edit: 10 Apr 2014 06:11 by martin_csr.
  • Tumbleweeds
10 Apr 2014 08:52
#628551
Yeah it seems the different size needle jets are obsolete. I have new round mains and some pilots coming. I got 17.5 pilot set and 2 sets of mains. 105s and 107.5s
That should get me back in range of where I should be.
On the hunt...
