29 smoothbore mixture screw setting ??
- mtkawboy
04 Apr 2014 09:43
I have an 1105 motor, street porting, 10.25 -1 pistons, 395 lift 260/260 cams, Kerker exhaust, oil cooler & 29 smoothbores with K&N pods. All the specs Ive seen on mixture screws call for 1 1/2 out and my bike wont run like that. It wants to be like 1/8 to 1/4 out. Im also at 3700 ft elevation. The bike runs great like it is but Im curious as to why it wont run at everyones mixture specs. Also is in on the mixture screw rich or lean ? What weight oil do you guys run ?Thanks for you help
- toad
Re: 29 smoothbore mixture screw setting ??
05 Apr 2014 06:22
turning in screw should be richening . Look for setting at highest idle, Mine is at 1/2 turn
15/40 Rotella
15/40 Rotella
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- Gman
05 Apr 2014 06:31
It depends on what size slide cutouts you have in your 29's. 1.5 mm slide cutouts should require 1 1/4 - 1 1/2 turns out on the screws. If your cutouts are 2.0 or 2.5, the setting for the Kaws is no more than 1/4 turn on the screws. I believe the larger cutout slides were made for Suzukis and Honda 750s. Once you find a setting that works, just leave it. It should idle just like stock carbs.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
The following user(s) said Thank You: mtkawboy
