Identify these carbs?
  • DobbinsCMA
  • DobbinsCMA's Avatar Topic Author
31 Mar 2014 11:55
#627226
Which carbs are these?
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: Identify these carbs?
31 Mar 2014 11:58
#627228
They look to me like Mikuni VMs with an a/p. Someone will surely confirm or deny this!
  • DobbinsCMA
31 Mar 2014 15:47
#627266
they are off of my Kz1000. I am cleaning them. any suggestions would be much appreciated. Video would be awesome!
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • zed1015
  • zed1015's Avatar
31 Mar 2014 15:57
#627267
Yes! VM's with accelerator pumps.
Judging by the pic's they 28mm.
  • Tumbleweeds
  • Tumbleweeds's Avatar
31 Mar 2014 19:04
#627320
They are VM28ss
On the hunt...
4/2/14-1977 KZ650 B1 17k miles
  • DobbinsCMA
01 Apr 2014 06:47
#627390
Well found out they are VM26 with pump because they have a second diaphragm on the bottom. Since mine is a LTD that would make sense.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • Tumbleweeds
01 Apr 2014 09:45
#627417
I was using this reference to your photo:
On the hunt...
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
01 Apr 2014 13:04 - 01 Apr 2014 13:07
#627442
Though not a video there is a pretty good write up here on cleaning a set of vm26ss carbs off of a Suzuki. www.thegsresources.com/garage/docs/vm_carb_rebuild.pdf
As to which set of carbs you have there should be an ID stamped just below the choke lever. If you post what yours are we should be able to tell you just what you have. Ssee attached for location of ID - please note the pic is of a set of vm24ss carbs and not a set of vm26 or vm28 carbs - but the location of the ID stamp should be the same.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 01 Apr 2014 13:07 by gd4now.
  • Gman
  • Gman's Avatar
05 Apr 2014 06:44
#627933
Looking at how thin the walls are on the intakes where the airbox boots slide on, they look like 28's. Measuring those openings with a set of calipers will tell you for sure.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
