Plastic Plugs for Pilot Jets on KZ440
  • Kz Carl
  • Kz Carl's Avatar Topic Author
28 Mar 2014 08:29 - 28 Mar 2014 08:30
#626890
How do these come out? Mine spin, but don't unscrew, I pull but am afraid they will crack. Thanks, Kz Carl
Last edit: 28 Mar 2014 08:30 by Kz Carl. Reason: more accurate
  • JR
  • JR's Avatar
Re: Plastic Plugs for Pilot Jets on KZ440
28 Mar 2014 08:43
#626894
I have the same plug - Kawasaki call them "cap polyester" in my 1980 KZ750/4 carbs and it looks like they they were used on the 440s also.
They just pull out The only thing holding them in place is an O ring.
  • Kz Carl
28 Mar 2014 11:37
#626911
Thanks, I will yank harder!
  • undiablo
  • undiablo's Avatar
28 Mar 2014 11:58
#626912
If you are already there, you can replace the o'rings of the polyester caps. That cap is intended to let the slow pilot jet feed through the main jet, no directly from the float bowl.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
