Another jetting issue...
  • Doogie
  • Doogie's Avatar Topic Author
23 Mar 2014 19:46
#626311
Well in my novice attempts at building my first bike I did the unthinkable....
I am running pods and straight pipes!
I know, I know...
So, everything runs great. The bike idles and revs properly. I ordered a jet kit from 6 Sigma from Amazon/eBay and everything worked pretty well but now I am trying to fine tune everything.
When test riding my bike it starts out fine but at about half throttle it falls flat on it's face. I have no power. I am not sure whether or not I am getting too much fuel or too much air. I have searched and read both as being the cause to the problem.
Any and all help or suggestions would be great. I am planning on buying jets, most likely mains, and starting to try to figure this out.
Thanks in advance!
81 KZ440 LTD
83 KX550A
82 GS450
74 CB360
When in doubt...brute force.
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Another jetting issue...
24 Mar 2014 05:25
#626323
What color are the plugs? Black = mains too large. White = mains too small.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • Doogie
24 Mar 2014 19:58
#626453
The plugs were definitely black. They were not wet and not sooty.
Fuel was leaking out of the overflow leading me to think that I was too rich and all the fuel was not being used.
Thanks for the help.
Now I need to figure out what size the OEM main jet is and which ones to buy...
81 KZ440 LTD
83 KX550A
82 GS450
74 CB360
  • bountyhunter
  • bountyhunter's Avatar
24 Mar 2014 23:15
#626463
Doogie wrote: The plugs were definitely black. They were not wet and not sooty.
Actually that means it's flooding. You need to clean or replace the needle valves/seats and adjust the fuel levels.
  • Jrbrownie00
  • Jrbrownie00's Avatar
28 Mar 2014 07:44
#626885
Make sure nothing on the carbs blocked. I had some gunk in one of the passages that caused the same type of problem.
82' kz750 ltd.
