Stuck Air Jets
  • daless
  • daless's Avatar Topic Author
Stuck Air Jets
19 Mar 2014 12:27
#625776
Any tips on how to best remove the stuck air jets from my VM29s? Only got one out successfully, the tops are all junked up on the others. No more slot for a screwdriver. Trying to be delicate as possible here... :unsure:
'77 KZ1000A1 - Mikuni VM29s, Kerker 4-1, K&N pods, LTD mags, Z2 seat
  • JimB
  • JimB's Avatar
Re: Stuck Air Jets
19 Mar 2014 12:41
#625778
I am going to assume you sprayed them with PB blaster to similar liquid let them sit overnight. If not then I would do that before playing witih it any longer. You can spray them from the top as well as from the intake opening i believe.
Then I would try a small left handed drill bit
Good luck. Take your time they are expensive Carbs.
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
