Carb rebuild kits
  • Greasedmonkey
  • Greasedmonkey's Avatar Topic Author
Carb rebuild kits
16 Mar 2014 20:12
#625485
I need to rebuild the carbs on my 80 kz650. Since Im fairly new to these bikes, I dont know which ones I have and I have yet to still find a labeled kit for my year and model bike. If anyone can help, I would love you for ever!
1980 KZ650E
  • Nessism
  • Nessism's Avatar
  • Away
Re: Carb rebuild kits
16 Mar 2014 21:32
#625488
Rebuild kits are a gamble. Full of often times inferior aftermarket jets that may or may not be correct for your application. If your bike has VM Mikuni carbs, you can get an O-ring kit from cycleorings.com. That and maybe float bowl gaskets should be all you need.
  • martin_csr
  • martin_csr's Avatar
17 Mar 2014 07:01 - 20 Mar 2014 16:45
#625524
+1 ... . The CylceOrings guy has been selling the kits for a number of years.
Z1Enterprises.com has the float bowl gaskets & top gaskets.
I don't think replacing the top gaskets is critical or anything - I just soaked mine w LW silicone spray.
Z1Ent also has the starter (choke) plunger caps.
If you need new jets or you need to get larger, Z1Ent has K&L -- made in Japan & oem quality.
I would disassemble & clean the carburetors and inspect the little brass parts. I bet they are fine.
Use your eyeballs & common sense.
Last edit: 20 Mar 2014 16:45 by martin_csr.
  • Nessism
  • Nessism's Avatar
  • Away
17 Mar 2014 08:05
#625531
One other issue with "carb kits" is they don't contain all the various O-rings you will need for the job, the carb interconnection tube O-rings for example.
  • WhiskeyB
  • WhiskeyB's Avatar
17 Mar 2014 17:07
#625585
+1 on the cycleorings.com site. I actually got more o-rings than I needed for my application (I think his is intended for the Suzuki version of the Mikuni BS34), but it was very complete, including the o-rings for the fuel/vent tubes between carbs.
+1 also for Z1 and for K&L carb parts. If you're having trouble figuring out what you need, call them. They know an awful lot about this stuff, and they carry the best aftermarket stuff you're likely to find.
1982 GPz 750
  • Greasedmonkey
20 Mar 2014 15:47
#625933
I do know I need bigger jets. I have pod filters and an aftermarket exhaust. I will look into those sites and see what I need. Thanks
1980 KZ650E
  • martin_csr
20 Mar 2014 16:47 - 20 Mar 2014 16:47
#625939
A good starting point on the jets for VM24 carbs, pod filters, & 4-1 exhaust is
#17 pilot jets & ~#115-120 main jets.
Last edit: 20 Mar 2014 16:47 by martin_csr.
  • Greasedmonkey
21 Mar 2014 17:52
#626087
Sweet, that should help a lot. I cant wait to get everything I need and get the bike running again.
1980 KZ650E
