Carb problems?
- vondikka
11 Mar 2014 17:13 #624871
by vondikka
78 KZ650 C2
76 kz400 D3
Carb problems? was created by vondikka
78 kz650c2. I can't open throttle without choke on, which is weird because about a week ago it started right up and ran fine.
I'm running 2 shorty mufflers from DCC, pod filters, 17.5 pilots, 112.5 mains, needle clip middle. New coils, points, and condenser. Ngkb7es plugs correctly gapped.
I'm definitely getting fuel and spark, and have good compression. Carbs were completely cleaned about a week and a half ago, new fuel filter, clean gas tank, fresh fuel.
Any suggestions?
Any suggestions?
78 KZ650 C2
76 kz400 D3
- vondikka
11 Mar 2014 17:18 #624874
by vondikka
78 KZ650 C2
76 kz400 D3
Replied by vondikka on topic Carb problems?
The only thing that happened between a week ago when it started, and now, is that I made a tack weld without disconnecting the battery first. I thought this may have fried some electronics but they seem fine. Could this have caused a problem that I may be unaware of?
78 KZ650 C2
76 kz400 D3
- baldy110
- Thank you received: 512
11 Mar 2014 18:41 #624892
by baldy110
Replied by baldy110 on topic Carb problems?
That is the classic symptoms of a clogged pilot jet system. You might have gotten some debris in the float bowls. Clean the jets mains and pilot and make sure all the small passages ways in the carb bodies are clean and clear.
- gd4now
- Denco where did you go?
- Thank you received: 443
12 Mar 2014 00:30 #624921
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Carb problems?
Check for air/vacuum leaks on the carb holders or test ports.
1977 KZ650 B1
- vondikka
12 Mar 2014 17:51 #625003
by vondikka
78 KZ650 C2
76 kz400 D3
Ok, so I pulled the carbs and cleaned all jets and orifices. Put back together and it wouldn't start.
Then upon turning the killswitch to off, I would heard a pop in the exhaust. I'm confused.
78 KZ650 C2
76 kz400 D3
- vondikka
12 Mar 2014 18:32 #625007
by vondikka
78 KZ650 C2
76 kz400 D3
It also backfires every so often while I'm trying to start it. And the smell that comes out of the exhaust, right after the pop, is something I've never smelled before.
The starter engages for a split second as I turn the stop switch to off. That's when the pop occurs.
78 KZ650 C2
76 kz400 D3
- baldy110
12 Mar 2014 18:58 #625009
by baldy110
Check your battery, it's cables and grounding wires. Are you sure you put everything back together properly?
- vondikka
13 Mar 2014 12:17 #625059
by vondikka
78 KZ650 C2
76 kz400 D3
Checked my grounds and connections and they were ok. Started thinking that it was timing related so I adjusted my points again and after several kicks, it fired up and ran normally without the choke.
78 KZ650 C2
76 kz400 D3
