Are the 28's with acc pump any good?
- kzz1king
10 Mar 2014 14:48
Just bough a 79 Mark II motor with the 28 ans a acc pump. Are these carbs pretty decent. I am pretty sure I will be using them with pods and a header as I have no airbox. Just looking for a little feedback on them.
Wayne
Wayne
Home built KZ1000 turbo setup
- loudhvx
Re: Are the 28's with acc pump any good?
10 Mar 2014 15:04
Yes, once you eliminate the accelerator pump and rejet accordingly. Since you wil be rejetting anyway, not an issue. You just need a block-off plate.
The pump was really more of an emissions/fuel-mileage issue, in my opinion. It allowed for leaner jetting while cruising, while still enrichening during acceleration. Upjetting the pilot and/or needle is more consistent and gets rid of a bunch of variables.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- les holt
10 Mar 2014 17:32
If you do remove the pump setup, I'd be interested in the whole setup.
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- GPzEric
10 Mar 2014 18:08
I liked the accelerator pumps - on a warm day I'd hop on it, twist the throttle a couple of times, and fire it up with no choke required.
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
- kzz1king
10 Mar 2014 18:48
I will keep that in mind Les. One slide is stuck pretty tight in the bore. I think I will give the pump a try if I get these working. That does souns nice GPZEric.
Wayne
Wayne
- les holt
10 Mar 2014 19:00
Hey, just let me know!
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
11 Mar 2014 11:21kzz1king wrote: I will keep that in mind Les. One slide is stuck pretty tight in the bore. I think I will give the pump a try if I get these working. That does souns nice GPZEric.
Wayne
A heat gun on the carb body will soften the varnish post haste, and allow the slide to fall free.
- kzz1king
11 Mar 2014 18:14
Brilliant minds think alike! That is what I did and it worked great! Then I read it here
Nessism wrote:kzz1king wrote: I will keep that in mind Les. One slide is stuck pretty tight in the bore. I think I will give the pump a try if I get these working. That does souns nice GPZEric.
Wayne
