Vacuum Petcock leaking even after rebuild.
  • 82KZcafe
  • 82KZcafe's Avatar Topic Author
07 Mar 2014 11:11
#624433
I have an 82 Kz 750 LTD with a vacuum petcock. It would not stop leaking into my carbs so i order a rebuild kit after realizing one of the diaphragm gaskets was torn. Now when it is placed in any position it will flow gas. There is no way to shut it off. I tore it apart again to make sure everything was back together correctly and it was. Don't know if i just need a different one. If so should i switch to a manual petcock and plug the vacuum?
  • undiablo
  • undiablo's Avatar
Re: Vacuum Petcock leaking even after rebuild.
07 Mar 2014 13:16
#624438
Does the o'ring seat correctly? The spring is still strenght?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
  • martin_csr
  • martin_csr's Avatar
07 Mar 2014 13:22
#624439
What brand was the diaphragm kit? When you installed it, did you reuse the plate that kinda fits in between the diaphragm? Did you clean & inspect the mating surface where the diaphragm o-ring contacts it?
Here's a manual fuel valve topic. KZR topic - Manual fuel valve option
