Kz1000 shaft rich with pods
- ChopFinger123
Has anyone else had this problem before?
I plan on putting the stock air box back on as soon as i get the parts for it so i don't wanna rejet it.
Sent from my SCH-S720C using Tapatalk 2
- 74ullc
- Thank you received: 23
Without changing jetting, pod filters should cause it to run WAY lean. Resist the temptation to keep riding it like this. Get the airbox back on there first. Then if you're still having problems you can start nailing them down.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- koolaid_kid
- Thank you received: 99
Wait until you have the airbox installed, test, then report your results.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- ChopFinger123
- ChopFinger123
- Nebr_Rex
- Thank you received: 300
ChopFinger123 wrote: Got the box installed still pops out number 1&2 carbs and those 2 cylinders are running way cooler than the other 2.
Why don't you post the same reply on just one thread instead of multiple threads?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- ChopFinger123
- Thank you received: 2098
ChopFinger123 wrote: Got the box installed still pops out number 1&2 carbs and those 2 cylinders are running way cooler than the other 2....
Would suspect lack of combustion, perhaps due to insufficient cleanances on intake valves.
- 74ullc
You have a factory service manual correct? You need to just do the entire ADJUSTMENT-ENGINE section in the book. There are so many things it could be, just run thru that list and you will narrow it down.
You will almost certainty need to replace the carb holders if they are original. They will leak and cause popping at idle. You can check for leaks with a can of carb cleaner, spray around the base where the holders meet the head and see if idle changes, if so you found a leak.
Look at this thread....(not exact to your situation but close enough)
www.kzrider.com/forum/3-carburetor/59157...ff-idle?limitstart=0
....there is a list posted by Patton, along with some good info, and then he posted a pic about cleaning the pilot system in the carbs. On page two I posted a list from my manual of 'preliminary checks' to do before adjusting the carbs. I bet your manual has a similar list.
Keep at it and eventually you'll figure it out, you still have a lot of things to check.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
