Choke turned off turns to lurching and dying
- freakinbike
03 Mar 2014 09:01
I recently finished a top end rebuild which included a carb rebuild. I bench synced them and turned all of the vacuum screws 3 turns out (they were completely screwed up before the rebuild, so I didn't have anything to work off of). I started the bike with the choke on and it ran very very weakly. I hopped on and turned the choke off and the bike started to lurch (similar to popping the clutch with no throttle), then died.
While it was running, it would shoot out big blue sparks from the pipes (unspent fuel charges?).
I don't own a vacuum syncronizer, so I'm wondering if I should get one and if a sync would solve this issue. 1982 GPz 750, stock.
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
1973 VW Bus
- peter1958
- Banned
Re: Choke turned off turns to lurching and dying
03 Mar 2014 09:42
Could be the cam chain is off by one . Just a thought
www.kzzone.com/
- baldy110
03 Mar 2014 10:03
Double check your cam timing and if it is correct, your carbs are still dirty and clogged.
- sbc1320
03 Mar 2014 10:14
What baldy said ^^^^.
It it still does it then yes the carb is too lean and needs the choke to help it out.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- koolaid_kid
04 Mar 2014 06:42
The GPz models used the Mikuni carbs, which required a complete carb rebuild, not jut spraying with carb cleaner. New o-rings also. PITA, but they work well in the end.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
