Carburetor opinions please!
- Zapzuta
26 Feb 2014 17:48 - 26 Feb 2014 18:22
Ok here it is. 1976 Kz 900, 1075 kit, blue printed, welded crank, head is ported to max with kibble white ss valves, shim under buckets and 3x Andrews cams. I want to change from 29 mm smooth bores to new technology witch carbs and set up should I use? Also my 29 mm smoothbores might be for sale:) they are in very good shape and are painted engine grey (correctly) with chrome covers.
Last edit: 26 Feb 2014 18:22 by KZQ.
Re: Carburetor opinions please!
26 Feb 2014 18:03 - 26 Feb 2014 18:22
New technology would be fuel injection. That sounds like a lot of money, work, money, trial and error, and money to me. Other than the desire to employ new technology, is there an underlying reason you wish to remove the smoothies (poor performance, maintenance, etc.) ? Ed
- Zapzuta
26 Feb 2014 18:14 - 26 Feb 2014 18:23
I don't want fuel injection just newer carbs. 33mm, or 34mm. Don't know witch manafactur makes the best.
Last edit: 26 Feb 2014 18:23 by KZQ.
- zukdave
Re: Carborator opinions please!
26 Feb 2014 18:19
I'd think with your mod's a set of 33-34 mm flat slide's
if your're staying with carb's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- ffe
03 Mar 2014 12:20Zapzuta wrote: Ok here it is. 1976 Kz 900, 1075 kit, blue printed, welded crank, head is ported to max with kibble white ss valves, shim under buckets and 3x Andrews cams. I want to change from 29 mm smooth bores to new technology witch carbs and set up should I use? Also my 29 mm smoothbores might be for sale:) they are in very good shape and are painted engine grey (correctly) with chrome covers.
I got dibs on your 29s if you go to sell them. :whistle: shoot me a pm or better yet email if you do.
Doug
- LarryC
03 Mar 2014 13:40 - 03 Mar 2014 13:43
Mikuni RS34 will work fine. Schnitz Racing always seems to have the best price on Mikuni Flat Slides. I hate to tell you but you take full advantage of the RS34 Flat Slides, your cylinder head should be reworked at the port entrance. You can simply bolt on J intake manifolds and install the new carbs but the port entrances will be too small for optimal setup.
You may also need richer needles or the next size needle jet for the carburetors. Fuel just isn't what it once was and everything seems to want more of it these days. You'll have to see what works for you with your particular setup and your environment.
Larry C.
Last edit: 03 Mar 2014 13:43 by LarryC.
