Carburetor drain plugs
  • djaekley
  • djaekley's Avatar Topic Author
24 Feb 2014 14:58
#623208
This is not really a serious problem; more of a 'wondering why.'
I own a 78 KZ1000A2 and am working on the carbs. I'm wondering why the drain plugs on float bowls on carbs 2 and 3 face each other toward the middle of the bike instead of toward the outside (parts book shows them this way, as well)? Seems like it would be more convenient to switch them so that the drain plugs on the left 2 carbs face the left side and those on the right 2 carbs face the right side. I'm just wondering if anyone knows whether there's a good technical reason why Kawasaki placed them like this before I switch them to suite my preference.
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Away
Re: Carburetor drain plugs
24 Feb 2014 15:41
#623210
They're suppose to face away from the middle just like you think. Someone messed up the reassembly and probably didn't notice until they had already mounted the carbs back on the bike.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • 78z1Joe
  • 78z1Joe's Avatar
  • My man cave is my garage....
05 Mar 2014 16:06
#624280
As I understand it, the bowls need to be swapped, not the entire carb.
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
05 Mar 2014 16:41 - 05 Mar 2014 16:45
#624283
StreetfighterKz wrote: They're suppose to face away from the middle just like you think. Someone messed up the reassembly and probably didn't notice until they had already mounted the carbs back on the bike.
Later, Doug
That was my initial reaction too, but then I looked at the Kawasaki.com parts diagram and noticed they seem to show #3 facing inward. It's hard to tell which way #2 faces in the diagram. Very strange. If it was mine I'd look at swapping #2 bowl with #3 bowl to see if there's any reason not to swap them. Make sure the inside of both bowls are the same configuration. I can't image why they would have #2 & #3 facing inwards. Seems like it just makes draining them more difficult. Ed
Attachment 00007_2014-03-05.jpg not found
Last edit: 05 Mar 2014 16:45 by 650ed.
