81 KZ1000 hesitation from stop to start
- Magoogle
23 Feb 2014 06:35 #623061
by Magoogle
Just about finished my custom KZ project.
Current jet 40/140, 2 turns out. K&N pods and stock exhaust with the baffles cut off. Carbs are vacuum synced.
The issue is that I have having some "sputtering" or hesitation on the initial GO. But once above 2 or 3k rpm the bikes mid-high is awesome.
Where should I start my adjustment to get my low where I need it?
81 KZ1000 hesitation from stop to start was created by Magoogle
Attachment 2014-02-2021.23.54.jpg not found
- Magoogle
23 Feb 2014 14:32 #623080
by Magoogle
Replied by Magoogle on topic 81 KZ1000 hesitation from stop to start
fixed it by using some thin gauge steel plate cut to fit the opening of the exhaust pipe. Then drilled a single hole through that.
- DoubleA
23 Mar 2014 10:44 #626238
by DoubleA
79 KZ1000 ST
Replied by DoubleA on topic 81 KZ1000 hesitation from stop to start
I am having a similar issue, So just for my own clarification, you increased the back pressure on the exhaust and that fixed it?
79 KZ1000 ST
