kz1000p carb questions
  • Markovich
  • Markovich's Avatar Topic Author
20 Feb 2014 10:20
#622872
Hi there, new member here. I just picked up a 1990 Kz1000p and am in the process of bringing it back to life, I hope. I have two questions. What carb rebuild kits do you recommend and do you have a preference for where to get them? I guess three questions. I plan to use pod filters and stock exhaust, what jets do you recommend or do I need to change them? Thanks for the help, Keith
1990 KZ1000P, 72k miles, 10 years in storage, new, bars, tires, chain and sprockets, seat, carbs cleaned, police equipement removed.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: kz1000p carb questions
20 Feb 2014 13:27
#622886
Kits cost a lot and I have never bought a kit. Just clean the carbs real good and pay particular attention to the float needle seat. I clean mine with brasso and a Q tip. If that doesn't work for you then buy the kits.
If the bike has 34's I would jet them 40/140 to start. Roy
  • Markovich
20 Feb 2014 13:34
#622887
Thanks for the info. Yes it would get spendy for the kits. I will disassemble as suggested, clean and get those jets.
  • baldy110
  • baldy110's Avatar
20 Feb 2014 13:39
#622888
If you are just adding pod filters I would leave the stock jetting alone and just shim the needles.
  • wireman
  • wireman's Avatar
22 Feb 2014 17:13
#623039
I would try and keep a stock airbox myself to save lots of tining headaches.
  • Markovich
22 Feb 2014 19:01
#623048
Wireman, after mulling it oover for a few days, I agree that keeping the stocker is the way to go. Thanks for the input by all. Keith
