- Thank you received: 4
76 kz750 choke question
- fastidiots
18 Feb 2014 03:52 #622641
by fastidiots
82 KZ1000 J
76 KZ750 B1
76 kz750 choke question was created by fastidiots
Just picked up a 76 kz750b1. Carbs were off it and had already been rebuilt. After putting carbs back on the bike I discovered that there is nothing to hold the choke lever in the closed position. You can lift the lever to choke the bike but it just falls down when you let go. I assume there should be a spring or catch to hold it but I don't see any obvious place where it would go. Thanks in advance!
82 KZ1000 J
76 KZ750 B1
- Thank you received: 2829
18 Feb 2014 05:14 - 18 Feb 2014 05:20 #622646
by 650ed
Replied by 650ed on topic 76 kz750 choke question
There should be a screw, spring, and 2 washers that apply pressure to the little choke lever. The screw can be adjusted to make the lever tighter or looser depending on how much pressure it applies to the spring. The diagram below shows the parts for the KZ750-B1. Below that are 2 pics of the choke lever on the KZ650-C1. The carbs are different than yours, but it should give the general idea. Ed
Attachment 00006_2014-02-18.jpg not found
Attachment 000010.jpg not found
Attachment IMG_9617.jpg not found
Last edit: 18 Feb 2014 05:20 by 650ed.
The following user(s) said Thank You: fastidiots
- fastidiots
18 Feb 2014 06:05 #622651
by fastidiots
82 KZ1000 J
76 KZ750 B1
Replied by fastidiots on topic 76 kz750 choke question
Thanks! I will try tightening that up later today.
82 KZ1000 J
76 KZ750 B1
