z1r turbo fuel Weber45 or not?
- mrdatsunturbo
- mrturbo Norway
17 Feb 2014 23:14
what is the best set up on fuel side on z1r turbo?
Is it OK to drive around with Pingel Valve or will it be better to do an electric pump ?
If electric what
pressure will be best for the carb? and have somebody tried weber 45 on this engines?
If electric what
Attachment 1376142703622.jpg not found
Re: z1r turbo fuel Weber45 or not?
18 Feb 2014 08:25
I run a Pingle valve and motor doesn't starve for fuel on the street without running my fuel pump.
I put a Mikuni 42mm flatslide HSR carb on my bike when the old carb died. I will be getting the float bowl extention kit which increases the fuel available to the motor . Fuel pump pressures are around 3 PSI and I feel needed for dragstrip type passes so the motor doesn't go lean under hard boost conditions.
For more professional advise check out Mr Turbo website. And talk to Terry Kiser the owner and former race buddy of mine. He is doing turbos everyday
- turboking
18 Feb 2014 09:32
all atp kits came with a buzz box fuel pump and a fuel pressure regulator .....using a bendix/zenith psi was limited to 2 lbs or less for street applications.... turbo's need a constant/ smooth fuel supply ..... :ohmy: racing/ drag strip kits used a bigger pump with more psi ......... all my turbo bikes have a pump & regulator...... cheaper than toasting a set of rings :S .IMO :S .............mikuni 42 mm flat slide is a way better carb. (weber).
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- turboking
18 Feb 2014 09:52
this is the pump and regulator supplied with all later ATP kits.......pic of facet pump and empi adjustable regulator
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- mrdatsunturbo
- mrturbo Norway
18 Feb 2014 10:10
Ok good news the pump is it o-20 psi or something else and also regulator
never seen that before. Any idea where i can by?
Thanks a lot for all help
- Grumpy Ole Artist
- Eschew Obfuscation!
18 Feb 2014 10:16
"Any idea where i can by?" The watermark in the background of the regulator/pump picture says "JC Whitney"
(I would try there!) :whistle: :whistle: LOL!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
- mrdatsunturbo
- mrturbo Norway
18 Feb 2014 10:19
oh sorry its not easy to see all ranges :whistle:
- Grumpy Ole Artist
18 Feb 2014 10:20
I'm here for ya man!
1978 KZ650 B2
- turboking
18 Feb 2014 11:30 - 18 Feb 2014 11:31
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationthey sell these at a lot of other places ...... :dry: they are all over flea bay.......
search :
empi fuel pressure regulator
facet fuel pump
to answer your question the pump puts out 4 to 6 psi.......... :huh:
search :
facet fuel pump
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
Last edit: 18 Feb 2014 11:31 by turboking.
