79 sr650 cluelessness
- Britome
11 Feb 2014 19:25
I'm a newb with a bike that hasn't run in years. I've taken the carbs apart and I think things look fine and decent. Questions...
1) is there a no-brainer dummy proof checklist I can go over somewhere?
2) do I need to reseal the bottom caps for the float resivoirs or just tighten back up with current gaskets that look ok. Someone previously had put some red gasket seal over the old gaskets.
Thx. I don't even know what I'm asking!
Re: 79 sr650 cluelessness
11 Feb 2014 19:27
No sealer is needed on those gaskets. If the gaskets leak replace them.
- Britome
12 Feb 2014 06:33
I would install new float bowl gaskets. Z1Enterprises.com should have them. Be sure to get the correct gaskets, as there are slight differences depending upon the model/year. Carefully scrape off any red goo from the mating surfaces.
Verify that all of the carb passages are unobstructed. You could use carb spray &/or compressed air - wear goggles.
14 Feb 2014 05:05
There is more to cleaning the carbs than just pulling the float bowls. You need to make sure all the internal passages are open. At minimum, I'd pull the pilot jets and hold them up to the light to make sure the tiny orifice is not plugged. As for the float bowl gaskets, if they are not torn I'd reuse them.
14 Feb 2014 05:14 - 14 Feb 2014 05:15
Last time I looked, there were some good tutorials in the file base. There is a link on the home page of the forum.
Oops, the link is in the nav bar at the top of every screen.
Last edit: 14 Feb 2014 05:15 by TexasKZ.
- Britome
14 Feb 2014 18:52
I sprayed and blew things out pretty well. I want to see how it sputters once I get spark. Then if I need to, I'll go back in. Thx for the help and insight.
