- Thank you received: 3
Float level
- newoldride
- P21
- Thank you received: 34
not a bench sync
Kawasaki KZ 1000 Police (2002) P21
- JR
- Thank you received: 449
newoldride wrote: This is kind of a carry over from my other topic (Help tuning) but it made such a difference I thought it needed a topic of its own I adjusted the floats this morning per Patton's instructions and just got back from a short ride and it was day and night difference from the way it was running.2 of the carbs were way high but I didn't think it would make that much difference it sounds good and pulls hard now I need to do some throttle chops to make sure it's not lean with the 115 main jets.
I totally agree. Getting the fuel level at the correct height - measured not eyeballed - makes a huge difference. The first time I did this I knew before I even got the bike out of the driveway that it was way way better.
Like P21 says a proper synch will finish it off like icing on a cake
Good luck
- newoldride
- koolaid_kid
- Thank you received: 99
The top level of the fuel should be no higher than the highest lever of fuel in your gas tank so the pressure on the needle and seat is not too great.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- turboking
- Thank you received: 106
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- kaw-a-holic
- Thank you received: 249
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- daveo
- Thank you received: 661
kaw-a-holic wrote: I have always used my tank set off to the side on a Craftman portable work bench with a longer fuel line. I like the suggestions here better, im always nervous that I will knock my tank off the bench.
*Caution: This job should be left to those with experience and training, and should never be attempted by anyone without fully-considering the potential consequences of making a mistake. It is potentially hazardous to mess around with gasoline. And besides...it stinks.
If you have any reluctance, don't do it! If you blow up your garage and kill yourself in the process, don't blame anyone here for making a suggestion. :whistle:
1982 KZ1100-A2
- sbc1320
- Thank you received: 38
I do the same. I have some plastic nipples and longer lines I use for this. I take my tank off and set it up on my wooden work bench which is about 4 and half feet tall. Gonna set the tank up there anyways where it can't get hurt so might as well make use of it. Just as safe as being on the bike and probably even safer.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- newoldride
- daveo
newoldride wrote: Thanks for all the good idea's .and if I blow my self up and die I promise I won't say anything LOL
We'll hold you to it...:dry:
1982 KZ1100-A2
