Slow to get rpm down on throttle shutoff- pods
- racersteve
08 Feb 2014 10:09 #621541
by racersteve
Slow to get rpm down on throttle shutoff- pods was created by racersteve
Have 80 ltd 1000, bored out 2x, new pistons, valves, etc, new accel pump, mains and pilot jets increased. No air box, pods. Stock carbs otherwise. On throttle shutoff, bike very slow to come down off rpm. Would it need smaller pilot jets, or change in mains. Cables are new. Old bike mech. has spent time trying to tune, but claims old bikes just run that way and you can't expect instant shutoff, I disagree. Tips, suggestions? Thanks!
- koolaid_kid
- Thank you received: 99
08 Feb 2014 13:20 #621552
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic Slow to get rpm down on throttle shutoff- pods
Old mechanic incorrect, you correct.
That is usually an indication the pilot circuit is too lean.
1983 GPz 750
- Thank you received: 2829
08 Feb 2014 15:03 - 08 Feb 2014 15:03 #621562
by 650ed
Replied by 650ed on topic Slow to get rpm down on throttle shutoff- pods
Also, check your carb holders for leaks. Here's how:
Make sure the vacuum caps are tight on the carb holder nipples. Warm the engine up to normal operating temperature. Temporarily set the idle as low as possible without stalling the engine. It should be down below 1000 rpm. The lower the better because when it is set low the carb slides are closed (or nearly closed) and this raises the vacuum level in the carb holders. The combination of the increased carb holder vacuum level and the very low idle amplifies the effect of the leak test.
Once the idle is set low, spray carb cleaner around each of the carb holders where they bolt to the cylinder head and where the carbs attach to them. If there are leaks, the vacuum in the carb holders will suck the carb cleaner in and this will affect the idle. It may even cause the engine to stall. If the leaks are at the carb holder / cylinder head mating surface you need to replace the holders. If the leak is where the carbs attach to the holders you may be able to tighten the clamps enough to seal the leak. Some folks use starter fluid or other substances for the test, but carb cleaner works best as it doesn’t evaporate too quickly like ether and leaves no residue on the engine like WD40. Ed
Last edit: 08 Feb 2014 15:03 by 650ed.
