carb to airbox boots.plz help!
  • 849Cope
  • 849Cope's Avatar Topic Author
29 Jan 2014 12:11
#620481
Hi all.im searching for carb boots.the ones that go to the air box.I've checked ebay and z1 with no luck.does anyone have any they could part with or now of anywhere to buy some?the bikes a 78 kz750 twin.thanks!
  • martin_csr
  • martin_csr's Avatar
Re: carb to airbox boots.plz help!
29 Jan 2014 13:05
#620500
I think you're going to have to make your own. Try searching the internet for homemade airbox ducts or something like that. The part is apparently no longer available & Z1Enterprises.com doesn't seem to have anything, oem or otherwise. I checked the part number on eebbaayy, but there isn't anything listed right now - a nos item may come up for sale - I wouldn't buy used.
  • moneypit
  • moneypit's Avatar
29 Jan 2014 13:32
#620504
I think Martin is right, I couldnt find anything either.
But I found a mod that could work. See link
kz750twins.com/?p=275
Good luck
2-76 kz900
St Paul MN
  • cope849
  • cope849's Avatar
29 Jan 2014 14:29
#620508
Thanks a lot for the help guys and thanks moneypit i think that's what im going to do.
  • martin_csr
29 Jan 2014 14:56
#620514
If you go the homemade route, you'll have to make sure the connections are good & tight, ie, w no air leaks.
