Aftermarket controller for Kawasaki DFI?
- KZQ
- Administrator
27 Jan 2014 11:44
Seems that I read where a member here was modifying a digital fuel injection system on a Kaw to work with an aftermarket control box.
Would appreciate a link or some info.
Thanks
Bill
Thanks
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- nitrokeeb
Re: Aftermarket controller for Kawasaki DFI?
27 Jan 2014 13:47
www.kzrider.com/forum/4-electrical/47357...irt-microsquirt-a-kz
I just ordered a set of GPZ throttle bodies so I can someday do this to my LTD.
1978 KZ1000B LTD w/KZ900 engine
- steell
27 Jan 2014 16:04 - 27 Jan 2014 16:05
KZ1300? MicroSquirt won't work if you plan on doing the ignition also, ought to work for fuel only though.
ZX11 converted to EFI with MegaSquirt II, ZX12 converted to MS3 with 8 injectors and Coil on plug.
You can go for anything from simple fuel only to more complicated performance options.
Maybe someone at the KZ1300 board has done something ?
Last edit: 27 Jan 2014 16:05 by steell.
- DFIGPZ
27 Jan 2014 16:06May I ask what you are trying to accomplish ? you may not even need it .KZCSI wrote: Seems that I read where a member here was modifying a digital fuel injection system on a Kaw to work with an aftermarket control box.
Thanks
Bill
1984 750 Turbo
- KZQ
- Administrator
27 Jan 2014 16:48
The parts for Z & KZ1300 DFI systems are getting to be scarcer than donthavakawman's recent posts. I'm trying to build a system that would keep an injected 1300 on the road without resorting to purchasing used (worn) Kaw parts on evil-bay.
Thanks to everybody for their posts. I've got plenty to work with.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- zukdave
27 Jan 2014 17:24
Bill contact Joe at Pit Stop Performance
There's quite a few after market ECM's that would work for you.
Maybe talk to Lorcan on the GPz750 turbo site
those bike's run the same basic system.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- steell
27 Jan 2014 19:42 - 27 Jan 2014 20:08
I believe Lorcan has/had a ZX12R computer with a Power Commander on his 750 Turbo, or maybe just the Power Commander for a ZX12R, it's been awhile. The ZX12R runs sequential injection and is a four cylinder, so it wouldn't work very well on a six cylinder.
That might be a problem with most aftermarket ECUs, how many fuel injected six cylinder motorcycles are there? BMW1600 might be an option, but you'd need some way to edit the software, same with the Honda 1800, and aside from the Kawasaki 1300 those are the only six cylinder fuel injected bikes I'm aware of.
I think there is an ECU editor available for late model GM cars, maybe you could use an ECU off a car six cylinder? You're limited only by your imagination.
Still thinking: If you just want to run batch fire injection (fire all injectors at once), then you could use a lot of different ECUs, number of cylinders wouldn't matter. I'm not familiar with the 1300 system, but as long as the ignition is separate it would be pretty easy to use any batch fire ECU.
Last edit: 27 Jan 2014 20:08 by steell.
