Ballpark jets and needles KZ1000 with mods?
- HAFROD
23 Jan 2014 20:53
On my 78 KZ1000 with Mikuni 28 pumpers, I'm looking for a ballpark jet# and needle setting for UNI foam pods and an OPEN exhaust. I've read that the needles have different notches but I only see one. It does have two nylon washers. The jets in the carb now are 51 pilots and 115 on the needle jets. Are these stock? They both have a symbol on them that looks like a square with a smaller square in one corner. So what kinda mess have I got here?
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
- HAFROD
Re: Ballpark jets and needles KZ1000 with mods?
23 Jan 2014 20:59
Also, I just now used my digital caliper inside the small end of the carbs and they measure 30.25mm. I thought this was supposed to read 28mm ? ? ?
- Nebr_Rex
24 Jan 2014 03:54
Pic of said carbs?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- sbc1320
24 Jan 2014 05:53
15 pilots?
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- HAFROD
24 Jan 2014 07:02
Yes 15 pilots
- HAFROD
24 Jan 2014 07:17
24 Jan 2014 12:10
i am pretty sure you will need to go with 120 mains.
i think the 15 pilots might be okay to start with.
the no grooves on the needles kinda has me puzzled tho.
- DFIGPZ
24 Jan 2014 15:15
Later model 28mm carbs had a non adjustable needle.
1984 750 Turbo
- HAFROD
24 Jan 2014 16:40
What is stock jetting for 78 KZ1000A2a? Even though my caliper is reading 30, is it still considered a 28mm?
- dkoz
25 Jan 2014 05:21Attachment 1389465519408_2014-01-25.jpg not found
Take 2
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- dkoz
25 Jan 2014 05:24sorry those are the 26s when I get home I can lookdkoz wrote:Attachment 1389465519408_2014-01-25.jpg not found
Take 2
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- gd4now
- Denco where did you go?
25 Jan 2014 10:47
First you need to figure out if your carbs are vm26ss or vm28ss carbs, as it is my understanding that both were used during the 78 model year. You can measure them, to do so you need to measure where the slide meets the carb throat. But there should be an ID stamped on the flange of carb#1 just below the choke lever which may make it easier to ID..
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
