Advice on carbs please....
  • jarrad
  • jarrad's Avatar Topic Author
21 Jan 2014 22:52
#619581
Hey all i have 2 sets of carbs for my GPZ11 powered zed
Cv34's and vm28's
Both of them need a rebuild and the 34's need 4 new diaphrams!
As the 34's will be far more expensive to rebuild and i like the look of the 28's better i would prefer to use them.
I am wondering if they will be big enough?
Has anyone used this engine/combo?
Or just any opionoins?
  • ZERO
  • ZERO's Avatar
Re: Advice on carbs please....
22 Jan 2014 01:44
#619588
The 28s are standard and the 34s are C.V. type? Use a richer needle and jets with the 28s and it'll run fine. I'd like the looks better too.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
22 Jan 2014 06:08
#619595
properly jetted i wouldn't have a problem running the 28's.
probably be very responsive :evil: .
  • jarrad
23 Jan 2014 22:50
#619855
Thats good news as the 28's are cheaper to rebuild and look way better!!!!!
  • 531blackbanshee
  • Vendor
  • Vendor
24 Jan 2014 05:56
#619872
i don't believe you will regret it.
  • jarrad
25 Jan 2014 00:27
#619953
Leon any advice in jet size?
I live and ride at sea level and its generally 25+ degrees Celsius
Also i have one to replace one needle valve and seat, can i do just one or do i need to do them all?
Sorry but my knowledge on carbs is minimal....
  • jarrad
25 Jan 2014 13:07
#620005
Just a bit more info to help...
Seat valve- 2.3
Pilot -15
Mains have no stamping on them but i have a set of 135 mains that i believe
Would be ok as i think the standard was 120???
  • 531blackbanshee
  • Vendor
  • Vendor
27 Jan 2014 06:09
#620213
prolly ok to start with on the seat valve and the 115 pilot the 135 mians are going to be to fat i am afraid.i believe you will find your self closer to the 125ish range.
but i would not hesitate to fire it up with the 135 mains and see if it is not sluggish and burbles alot.
a jet change or two and a little screwdriver work and you will have them dialed in in no time.
  • z1kzonly
  • z1kzonly's Avatar
27 Jan 2014 08:03
#620221
Never Thaught about those 34mm C V's? GPZ 1100?
Are they worth anything? $$$ wise?
I think I have a set burried somewhere from the Drag racing days.
Those thin diaphrams always scared me.
  • Cynjut
  • Cynjut's Avatar
29 Jan 2014 13:02
#620498
As you get ready, be sure to get the right engine side carb mounts. The 34s and the 28s used different manifolds. I just did this conversion on my '82. Order the ones for the '77 A1 engine (as a reference).
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • jarrad
30 Jan 2014 00:07
#620575
Thanks mate ill keep that n mind.
