KZ1000 Carbs?
- KzDad
KZ1000 Carbs?
20 Jan 2014 16:20
Hello all, This is my first time joining a group like this but believe I may have bit off more than I wanted to chew. My son is a KZ fanatic and is very excited about rebuilding one. So of course he found one and now it is in our garage. The frame is a kz900 and has a kz1000a engine. The bike was not running when we purchased but it included the carbs that I pictured below. I am not sure I have properly identified them as of yet. It seems the diaphragm sensor area is not right. The diaphragm that i thought would go there has a needle that goes down the center and this one has a indention but not a hole. Is this diaphragm used on all models?
Any help or suggestions is greatly appreciated.
Attachment 2014-01-1519.49.14.jpg not found
Attachment 2014-01-1519.49.39.jpg not found
Attachment 2014-01-1519.49.06.jpg not found
Attachment 2014-01-1519.49.00.jpg not found
Attachment 2014-01-1519.49.41.jpg not found
Attachment 2014-01-1519.49.46.jpg not found
- Serpent7
- Nothing professionally, only for fun...
Re: KZ1000 Carbs?
20 Jan 2014 17:44
Should say Mikuni 28 on them if they are kz1000 carbs.
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
73 Volkswagen Thing
- JimB
Re: KZ1000 Carbs?
20 Jan 2014 17:45
Welcome, The triangle pump (very bottom) is typically not use and should be closed off, That looks fine. The square accelerator pump has a diaphram that should be replaced if the bike ihas been sitting for some time. But it looks like it's assembled properly. What is missing is the idle screw which should be sticking out of the hole. I also recommend taking them apart and cleaning them with carb cleaner
Have fun with this build,...these bikes are fun to work on and parts are readily available.
Jim
Jim
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
- KzDad
Re: KZ1000 Carbs?
20 Jan 2014 18:58
Where would it have the 28 I seem to be missing it or it isn't 1000 cc carbs
And yes the triangle is closed off.
- moneypit
Re: KZ1000 Carbs?
20 Jan 2014 19:13 - 20 Jan 2014 19:17
They wont have the size on the carbs. Most here know what carbs were on what year bike.
You can make sure by measuring the motor side of the carbs with a caliper inside dimentions will tell which size they are. Hence 28mm s stated in earlier posts. May also be 26mm carbs.
2-76 kz900
St Paul MN
St Paul MN
Last edit: 20 Jan 2014 19:17 by moneypit.
- z1kzonly
Re: KZ1000 Carbs?
20 Jan 2014 21:23
Hey, I need 2 of them small spring clips on the rubber hose barbs.
- sbc1320
Re: KZ1000 Carbs?
21 Jan 2014 05:03
They look like 28's to me and I have them on my 1980 KZ1000Ltd. I also have a fresh set of 26 pumpers off of a 79 KZ1000.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- RonKZ650
Re: KZ1000 Carbs?
21 Jan 2014 14:03
They look 28mm. Probably off a 1979-1980 KZ1000A.
- KzDad
Re: KZ1000 Carbs?
21 Jan 2014 20:45
I seem to be having a hard time finding the proper adjustment screw to complete this carb. Anyone have Ideas or where. To come up with one?
- kaw-a-holic
Re: KZ1000 Carbs?
21 Jan 2014 21:31KzDad wrote: I seem to be having a hard time finding the proper adjustment screw to complete this carb. Anyone have Ideas or where. To come up with one?
this may help.
www.mikunipower.com/catalog/mikunicarburetorcatalog2012.pdf
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Re: KZ1000 Carbs?
21 Jan 2014 21:36
sorry jumped the gun that won't help you any.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Re: KZ1000 Carbs?
21 Jan 2014 21:44
might try giving these guys a call.
www.sudco.com/Carburetor01.html
Sudco International, 2410 South Sequoia Drive, Compton, CA 90220
New Phone (01) 310 637 8330 • New Fax 310 637 8331
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
