- Thank you received: 5
What carbs and where to get parts and question
- HAFROD
09 Jan 2014 17:25 #618010
by HAFROD
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
What carbs and where to get parts and question was created by HAFROD
On my 78 KZ1000A2a, I took apart the carbs today. I found the gaskets at Z1 but what about the choke plunger rubber cap? Do these need to be tight so it gets no air leak or not and my old ones still OK to reuse? What are these carbs called? They are pretty intricate with ALOT of parts.
- roy-b-boy-b
- Thank you received: 103
09 Jan 2014 17:54 #618016
by roy-b-boy-b
Replied by roy-b-boy-b on topic What carbs and where to get parts and question
They are a VM series carbs.
- StreetfighterKz
- Thank you received: 117
09 Jan 2014 17:56 #618017
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic What carbs and where to get parts and question
Look like 28mm due to the accelerator pump hoses etc. on the fuel bowls.
Later, Doug
Later, Doug
1989 Vmax
- HAFROD
09 Jan 2014 18:40 #618029
by HAFROD
Replied by HAFROD on topic What carbs and where to get parts and question
Is the 28s good carbs?
- Thank you received: 2829
09 Jan 2014 19:27 #618033
by 650ed
Replied by 650ed on topic What carbs and where to get parts and question
If it's not too late, don't mix up parts between the different carbs. The parts tend to wear together and work best when they all stay in the carbs they started like in. Ed
- HAFROD
09 Jan 2014 20:59 #618045
by HAFROD
I marked the carbs and also the slides. I'm going to replace everything except the floats
- HAFROD
09 Jan 2014 21:06 #618047
by HAFROD
How about the rubber grommets on top of the choke plunger guys. Do they need to be new to not get an air leak or is an air leak there no big deal?
- koolaid_kid
- Thank you received: 99
09 Jan 2014 21:21 #618048
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic What carbs and where to get parts and question
No, the oring seals the plunger.
1983 GPz 750
