1982 GPZ1100 Carburetor Swap
- 1badanimal
09 Jan 2014 06:32 #617874
by 1badanimal
1982 GPZ1100 Carburetor Swap was created by 1badanimal
I have an 1982 GPZ1100 I am switching over to carbs. I am finding there is a small clearance issue with the oil cooler lines. Do they make a spacer to go between the block and the rubber carb holders. Or do they make a longer rubber carb holder manifold to space the carbs away from the block. I am trying to use BS34 carbs and the throttle linkage is hitting the rubber oil cooler line making the throttle difficult to operate thanks in advance for any suggestions.
- Thank you received: 797
09 Jan 2014 08:11 #617896
by 531blackbanshee
Replied by 531blackbanshee on topic 1982 GPZ1100 Carburetor Swap
- baldy110
- Thank you received: 512
09 Jan 2014 13:27 - 09 Jan 2014 13:28 #617960
by baldy110
Replied by baldy110 on topic 1982 GPZ1100 Carburetor Swap
I also swapped out the EFI on my 82 for the BS34 carbs a while back. I ended up making brackets to keep the oil lines for hitting the linkage.
Last edit: 09 Jan 2014 13:28 by baldy110.
