- Thank you received: 5
Carbs off my 78 KZ1000, what goes here?
- HAFROD
31 Dec 2013 15:55 - 31 Dec 2013 15:56 #616894
by HAFROD
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
Carbs off my 78 KZ1000, what goes here? was created by HAFROD
The triangle shaped thing. I removed the accel pump. There is something missing. Does it need it? What is supposed to be here. What does the outlet go to that they have a rubber plug on? Do I leave the plug?
Last edit: 31 Dec 2013 15:56 by HAFROD.
- roy-b-boy-b
- Thank you received: 103
31 Dec 2013 16:17 #616897
by roy-b-boy-b
Replied by roy-b-boy-b on topic Carbs off my 78 KZ1000, what goes here?
nothing.
- JimB
- Thank you received: 9
01 Jan 2014 10:56 #616966
by JimB
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
Replied by JimB on topic Carbs off my 78 KZ1000, what goes here?
Happy new year. The triangle, secondary accelerator pump should be blocked off with a little ball bearing and is not used. The nipple is an overflow port and since the pump is not used can be capped off. It looks incomplete but is fine as is. The square accelerator pump does not really do a lot either but you can check it by pumping the lever while on the bike with the air box and/or filters off and you will see a little gas spray come out. That is my experience with these accelerator pumps but I am sure someone more knowledgeable will chime in.
- Thank you received: 1656
01 Jan 2014 12:10 - 01 Jan 2014 12:11 #616972
by martin_csr
Replied by martin_csr on topic Carbs off my 78 KZ1000, what goes here?
The VM24 accelerator pump on my 81 650 is similar: the triangular vacuum sensor was disabled at the factory. A K&L rebuild kit includes the sensor diaphragm & spring, but the stuff isn't needed on models such as mine in which the sensor isn't functional.
The kit also includes a ball, weight, & clip: each float bowl should have those little parts.
The #2 bowl on my bike has 2 ports. One is for the carburetor overflow & the other one is for draining the carb.
Z1Enterprises.com - Accelerator Pump Kit - KL18-2903
Last edit: 01 Jan 2014 12:11 by martin_csr.
- HAFROD
12 Jan 2014 16:56 #618358
by HAFROD
Replied by HAFROD on topic Carbs off my 78 KZ1000, what goes here?
So the accelerator pump is not needed either?
