2 into 1 intake
- Schmeck
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
- sbc1320
- Thank you received: 38
Sorry my Kawasaki Brother, I had to do it. Hopefully someone will chime in for you though.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- Schmeck
- Schmeck
- bountyhunter
- Thank you received: 337
The whole intake and exhaust system is flow tuned. Getting it right is black magic. I wouldn't have a clue how to do it. I have read some stuff about it, but it's more art than science.Schmeck wrote: Can anyone explain to me the differences in using smaller diameter tubing vs larger tubing in an intake system . Also wondering if you were using larger tubing and put a small tube section in the middle to join the larger tubes, what effect would this cause ?
In general, narrowing the flow diameter increases flow velocity and creates a low pressure area. That's the basic principle of how a carburetor works (Bernoulli principle).
- Schmeck
- Schmeck
- Nebr_Rex
- Thank you received: 300
make any changes from stock. Your probably going to end up changing the pilot jet, slide,
main and needle. You'll need to do a search here on KZRider and other sights like do the ton
and chop cult etc...
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Schmeck
