- Thank you received: 1
jet advice for vm28sc on kz1000
- kamakazie1000
its a freshly rebuiilt 77 kz1000, new rings, valve job, etc.
originally purchased for 400 bucks, total basket case, hadn't run since '02, didn't have carbs on it when purchased
picked up a good pair of rebuilt stock carbs from a 74 z1a, have the 2 screws on top covers, and side angled drain screws on the bowls
other modifications include K&N pods, V&H 4-1 with a cone engineering reverse cone megaphone, dyna s ignition, dyna coils and wires.
im going to have a pro go through and do all the synch and tune, im just looking for advice on what size jets i should pick up before hand so i dont have to pay his prices to get them.
Thanks KZR community!
Terminal lance corporal of Marines, putting the GRUNT in disgruntled
kz1000 cafe project
- Cynjut
- Thank you received: 26
The carbs you've chosen are an unusual choice, so I expect you're going to have to experiment a little bit. There's no guarantee that these won't work stock. The good news is that they appear to be the same carbs used by Harley for that time period, so getting the parts should be relatively easy.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- etbike3135
- Thank you received: 50
1973 Kawasaki Z1
18 years in dragbikes
- baldy110
- Thank you received: 512
Cynjut wrote: The original carbs would be Mikuni RS28 or RS26s, IIRC.
FYI the Mikuni RS series of carbs were not around in 1977. The carbs you have sound like the Mikuni VM 28's, a good carb and should work fine.
- mtkawboy
- Thank you received: 16
- kamakazie1000
kz1000 cafe project
- mtkawboy
- Nebr_Rex
- Thank you received: 300
+1
Here is the stock jetting for the different years and models.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- z1kzonly
- Thank you received: 542
Stock motor, 122.5 or 125 better to be rich than lean.
Here is what you have, correct??
- Nebr_Rex
z1kzonly wrote: He is taking about Z1 1974-1975 28mm carbs. (2 screws on the top cover)
Didn't catch that. At least the info I posted can be used as a guide.
My st has an 1105 kit.with short duration cams, air box with K&N
and stock pipes. Cams are high lift, short duration, .390ish lift,
266°. Jetting is; 17.5 pilot, needle raised one notch and 115 mains.
I'm running the stock vm28 pumper carbs. The non pumper carbs
will need a little more fuel
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
