I was doing good until....this happened
- DER3Z
27 Dec 2013 21:51 #616549
by DER3Z
I was doing good until....this happened was created by DER3Z
I was taking apart the carbs to soak in a bath over night when all of a sudden chaos happened. I was getting the last rusty screw out when the carburator slipped and broke off the enrichener circuit I dont know what else to do, not sure if you can replace it or not or if im just screwed. If someone could help me out would appreciate it!
- roy-b-boy-b
- Thank you received: 103
28 Dec 2013 02:31 - 28 Dec 2013 02:32 #616557
by roy-b-boy-b
Replied by roy-b-boy-b on topic I was doing good until....this happened
It should start alright with just three enrichers. If you can find another carb down the road you can replace it. Don't let this mishap stop your work looking for a carb.
It would help of you filled out your profile and put what kind of bike you have in the signature section. That way riders will know what help to offer.
Last edit: 28 Dec 2013 02:32 by roy-b-boy-b.
- etbike3135
- Thank you received: 50
28 Dec 2013 05:31 #616558
by etbike3135
1973 Kawasaki Z1
18 years in dragbikes
Replied by etbike3135 on topic I was doing good until....this happened
Those come out, easily with a little heat. Totally replaceable if you can get the end of what broke off out.
1973 Kawasaki Z1
- oldzed
02 Jan 2014 07:01 #617050
by oldzed
Replied by oldzed on topic I was doing good until....this happened
would anyone know if there is a source for these tubes?
- Cynjut
- Thank you received: 26
02 Jan 2014 09:09 #617067
by Cynjut
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Replied by Cynjut on topic I was doing good until....this happened
Seems to me Z1 Enterprises carried/carries them.
1977 KZ-1000 A1
- Thank you received: 2098
02 Jan 2014 09:55 #617070
by Patton
Replied by Patton on topic I was doing good until....this happened
If otherwise unavailable, damaged carb tubes are sometimes replaceable with an appropriate size brass tube from a hobby shop.
