Carb cleaner
- geerbangr
Carb cleaner
25 Dec 2013 02:59
Anyone ever use or have any luck cleaning carbs with lacquer thinner ?
1978 KZ 1000
I go by Jason
I go by Jason
Re: Carb cleaner
25 Dec 2013 05:46
Not me. Why not just use carb cleaner that is designed for that specific task? It is readily available at auto parts stores. Ed
- turboking
Re: Carb cleaner
25 Dec 2013 06:41
:blink: I've used lacquer thinner to remove pilot jets , emulsion tubes and slides. that were stuck and were not easily removed.
after soaking with lacquer thinner for a day or so they screwed right out
.........dissolved the crud/gum..
:pinch: but I've never used it as a carburetor cleaner . I have 5 gallons of carb dip for that :woohoo:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- peter1958
- Banned
Re: Carb cleaner
25 Dec 2013 09:33
Put them in a tub of diesel for a few days. Then use carb cleaner
www.kzzone.com/
- geerbangr
Re: Carb cleaner
25 Dec 2013 11:10
The reason I inquired about lacquer thinner is because I have 5 gallon that I've had for a while and if it would work I wouldn't have to cough up any dough for carb cleaner.
1978 KZ 1000
I go by Jason
I go by Jason
- turboking
Re: Carb cleaner
25 Dec 2013 11:46
imo , lacquer thinner by itself would not get them very clean at the very least not as clean as a carburetor dip/cleaner..... read whats in a can of dip....... :ohmy: more than one bad cleaner are used in the mix .... sure I like to save dough,
but if you want to do it right my guess is you have to ante up for some dip.... :dry:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- geerbangr
Re: Carb cleaner
25 Dec 2013 22:28
Looks like sound advice to me. What is the best cleaner the average joe can get his paws in ? I have auto zone near me.
1978 KZ 1000
I go by Jason
I go by Jason
- bountyhunter
Re: Carb cleaner
25 Dec 2013 23:16
I use carb spray or non chlorinated brake cleaner for cleaning car/bike parts. I also use acetone.
- turboking
Re: Carb cleaner
26 Dec 2013 05:02
I have a 5 gallon bucket of ZEP cleaner /dip Thinking I paid less than $ 100.00 at NAPA . I think the napa branded can is ZEP also
shop around to get the best deal.........
I'm sure auto zone , ,advance, koi, and others will carry different brands ...... of course the e.p.a. has tamed the solvents down in the last few years. I like the zep brand as it will remove most of the OEM black paint from suzuki carbs and
it does not damage rubber or plastic parts if left in the dip for less than 3 hours. :blink: be sure to wear gloves and eye protection as it will make you shed skin and eye damage if you get it in your eyes...... :S
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
Re: Carb cleaner
26 Dec 2013 05:09
i forgot to mention a bucket will last 5 to 8 years if you screen the solids out of it. I pour the cleaner thru a mesh screen into a 5 gallon plastic bucket....... after screening the dip I put it back in the metal bucket. :blink: screening the solids out keeps it working like it was intended to do( works better,lasts longer). :evil: you know it's bad stuff when it eats the metal can from the inside out :evil: LOL
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- geerbangr
Re: Carb cleaner
26 Dec 2013 22:25
I'm going to see if I can find some zep carb cleaner.
) thanks turbo
1978 KZ 1000
I go by Jason
I go by Jason
