Master Carburetor? 1981 Kz750 4
  • Koki
  • Koki's Avatar Topic Author
05 Dec 2013 16:25
#614872
I'm about to tune my carbs on a 81 kz750 4-cylinder bike and was wondering if there was a master carb that I set the other three equal to. Any info helps!
Cheers,
Koki
1981 Kz750E
  • martin_csr
  • martin_csr's Avatar
Re: Master Carburetor? 1981 Kz750 4
05 Dec 2013 16:42 - 05 Dec 2013 16:48
#614873
I don't think there's a master carb. You're supposed to synchronize them in pairs.
Sync 1 & 2 as a pair. Then 3 & 4 as a pair. Then 1-2 & 3-4 as a pair.
Here's a site w a manual & wiring diagrams. mbsween.bike-night KZ750L3 page
Scroll down & click "The Bible" link. Pg 15 has the carb sync procedure.
(note for the 750-Ltds: some of the wiring diagrams are mislabeled in the links. The 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4). search tags mbsween KZ750L3
Last edit: 05 Dec 2013 16:48 by martin_csr.
  • JR
  • JR's Avatar
05 Dec 2013 18:41
#614878
I have the 1980 750/ E1 with Keihin CV34 carbs which I am pretty sure is same as yours. The bike is under wraps until spring and it's a couple of years since I synced the carbs but I THINK (not totally sure) you will find that everything gets synced to the #2 carb. I think 1,3 and 4 are the only ones with set screws and lock nuts
I use the Morgan Carbtune tool.
Good luck.
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
05 Dec 2013 18:46 - 05 Dec 2013 18:48
#614879
I want to say it's the #2 carb... but I'm snowed in here, and am thus drunk.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Last edit: 05 Dec 2013 18:48 by guitargeek.
  • guitargeek
05 Dec 2013 19:27 - 05 Dec 2013 19:30
#614881
Also, EPIC CARBURETOR TUNING QUEST!!! [fistbump]
Last edit: 05 Dec 2013 19:30 by guitargeek.
  • zukdave
  • zukdave's Avatar
06 Dec 2013 03:56
#614896
On my VM29's the #2 carb is the LEAD carb all other's adjust to mach it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • martin_csr
06 Dec 2013 06:32 - 06 Dec 2013 07:36
#614910
Going out on a real skinny limb... Some mechanical slide carburetors have a reference or master carb, but some don't such as the VM24s on my 81 650. And I don't think his CV carburetors do either. However, in that pdf file at the KZ750L3 site, the carb sync instructions aren't real clear. For the 82 650 w BS32 carburetors the procedure is basically as described above.
The instructions for vacuum sync tools will say to calibrate the device by using the vacuum from the master carb, but I don't think it's applicable to all carb racks. For those that don't, I think you can use any carb to calibrate the tool.
Last edit: 06 Dec 2013 07:36 by martin_csr.
