- Thank you received: 2
kz 1000 LTD, plugs fouling on idle
- anotherZ
04 Dec 2013 08:44 #614753
by anotherZ
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
kz 1000 LTD, plugs fouling on idle was created by anotherZ
Hi everyone, I could really use some help here.
Bike is a 1979 KZ 1000 LTD with the pumper carbs. Runs well at mid range and top end. The bike has no mods except K&Ns and V&H 4in1
I was not able to get it idling properly on the original #15 pilots so I went one size up to #17.5. Idling was great right from the start with the mixture screws 1.5 turns out. However, plugs are fouling after a few minutes of stop and go. With the screws turned in, at about 1 turn, the bike doesn't idle that well anymore and plugs are still fouling.
Bike is in good mechanical shape, valves set correctly, new carb boots, new carb gaskets, new K&Ns, what am I overlooking? Plugs are NGK B8ES.
Thanks for any input!
79 KZ 1000 LTD
Smaller tank
- oldzed
- Thank you received: 10
04 Dec 2013 12:07 #614778
by oldzed
Replied by oldzed on topic kz 1000 LTD, plugs fouling on idle
check the voltage at the coils.
Should be close to battery voltage.
If not look for the " wired George mod"
- roy-b-boy-b
- Thank you received: 103
04 Dec 2013 13:59 #614783
by roy-b-boy-b
+1
Replied by roy-b-boy-b on topic kz 1000 LTD, plugs fouling on idle
oldzed wrote: check the voltage at the coils.
+1
- roy-b-boy-b
04 Dec 2013 15:25 #614786
by roy-b-boy-b
I just bought a bike so after posting I went out and checked my voltage at the coils and it was 9.75 . :pinch:
Looks like connector cleaning time. And a coil Mod.
- 4TheKZ1000
- Visitor
04 Dec 2013 16:49 #614790
by 4TheKZ1000
Replied by 4TheKZ1000 on topic kz 1000 LTD, plugs fouling on idle
I'm a big supporter of the Wired George system. 12.8 volts to coil 24-7 365 days a year
Attachment 0101024x826.jpg not found
- koolaid_kid
- Thank you received: 99
04 Dec 2013 19:16 #614803
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic kz 1000 LTD, plugs fouling on idle
The relay mod comes in many flavors. For example, I connected two relays in parallel for dual redundancy failure mode protection, send the output to an accessory fuse block, and run my coils, Fiamm horns, grip heaters, battery health signal and accessory outlet connector out of them. And still have an extra connection available.
1983 GPz 750
- anotherZ
30 Dec 2013 18:27 #616799
by anotherZ
79 KZ 1000 LTD
Smaller tank
Replied by anotherZ on topic kz 1000 LTD, plugs fouling on idle
Sorry everyone that I never replied....had not made my checkmark below I guess Will definitely take a look at this, have not yet checked voltage at the coils, will keep you posted!
79 KZ 1000 LTD
Smaller tank
