air bubbles
- SeabeeDan
air bubbles
30 Nov 2013 14:04
I have an 81 kz305. there's a clear fuel line with a fuel filter coming directly from the tank, if I move the line I can see air bubbles coming into the fuel tank from the carb. is this normal, doesn't seem like it should be happening. first thing to check?
- sbc1320
Re: air bubbles
30 Nov 2013 15:40
Doesn't hurt anything, sometimes they burp out of there or even work there way up the line. I just put new clear yellow fuel line on mine and mine does it. No lean issues at all on mine.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- Cynjut
Re: air bubbles
02 Dec 2013 11:54
There should be vents into the bowls on your carbs to help prevent this. It shouldn't hurt anything, especially if you are using an in-line filter.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- SeabeeDan
Re: air bubbles
03 Dec 2013 15:46
Cool, thanks guys. I'm just learning about carbs and air in the fuel line just didn't look right to me
- JR
Re: air bubbles
03 Dec 2013 19:34
Bubbles used to bother me until I got black opaque fuel line :whistle:
