79' MkII pumper carb hose routing?
  • MRNLaguna
  • MRNLaguna's Avatar Topic Author
30 Nov 2013 09:31
#614458
Anyone familiar with MkII pumper carbs, could sure use some info on vac. hose routing to and from bottom of #2 carb.(accel. pump float bowl) all carbs have been cleaned, new diaphragm installed, spring and ball under brass plug cleaned and replaced in # 2 bowl, brass pump nozzles to each carb cleaned out, new hoses between bowls replaced , still unable to get system to pump fuel? Looks like accel. Pump system gets its fuel from #2 bowl? I understand fuel inlet and overflow system from all carbs,except for one brass nipple from bottom of #2 bowl to?
Any and all advice would be much appreciated, any diagrams available, via the manual or online?
Thanks in advance, Mike
  • RonKZ650
  • RonKZ650's Avatar
Re: 79' MkII pumper carb hose routing?
30 Nov 2013 21:22
#614504
No real secrets, all 4 bottom breather lines just straight hoses to the rear of the motorcycle, the normal breathers facing upward go to the airbox, the normal vacuum nipple to the vacuum fuel valve. The pumper carbs are a real pain in the azz and don't pump is the norm for most.
The following user(s) said Thank You: MRNLaguna
  • MRNLaguna
02 Dec 2013 20:10
#614669
Thanks for the hose routing info, I'll keep messing with them up until I say the hell with it and just ride it the way it is I suppose. I can pre load gas directly into the pump and watch it come out each nozzle but it won't draw fuel on it's own. Might have to break the bank and find a manual for it or call Sudco in LA to see if they can help. Didn't the Kz650 also come with pumpers? Like 26mm or there about ?
  • RonKZ650
  • RonKZ650's Avatar
02 Dec 2013 21:32
#614673
Yea, the 79 KZ650 also debuted the pumper carbs in 22mm size. A little different set up, but same idea. Idea was to lean out jetting to pass emissions requirements, but spit in the extra fuel during throttle twist, just like an old rochester quadrajet carb on an old chevy from 1966.
The main problem was in priming the setup, the spray would happen good once it got going, but the float runs dry getting gas to initially start squirting was near impossible, hence the setup doesn't work the majority of the time.
  • MRNLaguna
06 Dec 2013 17:51
#614948
Thanks, that's good to know, might spend time on other aspects of the bike as it runs well w/o the pumpers working. I'll just pretend!
