Flatslide carbs
- Maravinchi
28 Nov 2013 12:51 #614302
by Maravinchi
"Quatre roues déplacent le corps, deux roues déplacent l'âme."
1983 KZ750 F1 Ltd-Shaft
Flatslide carbs was created by Maravinchi
No eBay APP ID and/or Cert ID defined in Kunena configurationIve seen alot of info on people using keihin drag carbs or old gsxr carbs. Has anyone tried using the mikuni 28mm flatslides on a kz750 (ltd shaft). The bike is stock I just want to get away from the cvs, I dont ride to far so im not worried about jetting issues. Thank you
- Nebr_Rex
- Thank you received: 300
28 Nov 2013 13:20 #614304
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Flatslide carbs, NOT!
Those are NOT flatslides.
Those are vm28s off a Z1 KZ900. These would be the same as bolting on the later vm26/28s.
Use the carb boots off the 900/1000 and elongate the holes. Subject has been covered before,
do a search will reveal the above info and more.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Maravinchi
28 Nov 2013 13:36 #614305
by Maravinchi
Replied by Maravinchi on topic Flatslide carbs
Ha my bad forgive my ignorance, i did a quick search and didnt find much info ill try and look a little harder next time. There not flat sides but there not cvs either right? Im just tired of tuning my carbs constantly only for them to quickly go back out of whack because of another vacuum leak. Alot of these seals and diaphragms are getting hard and expensive to find.
