33mm smoothbores on a 1015
- jp-15
27 Nov 2013 08:00 #614206
by jp-15
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
Dynatek S w/Green Coils.
Winter Project= 10.25:1 1015 cc kit w/ Web cams and Refurbished head. 33 smoothies hopefully.
33mm smoothbores on a 1015 was created by jp-15
Hi guys,
I'm rebuilding my 900 with a 10.5:1 1015 kit and a set of k410 cams. 4-1 with pods. Got a deal on a set of 33 smoothies off of kzr and I'm looking to se if these will be a good fit on this combo? What would a good starting point be on the jetting?
thanks,
Joe
thanks,
Joe
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
- turboking
- Thank you received: 106
27 Nov 2013 08:25 - 27 Nov 2013 08:27 #614209
by turboking
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Replied by turboking on topic 33mm smoothbores on a 1015
33's are a little large for a 1015 c.c. :dry: would work better with more c.c. , like 1132 c.c. to 1260 c.c. :blink: IMO :dry: 29 smoothbores would give you better throttle response and work better for any of these Z's , 903c.c. ,1015 c.c. ,1045 c.c., 1075 c.c. no matter what compression you use :ohmy: ..... :pinch: yet 33's are still doable if that's what you got...... :huh:
1985 GS 1150E
1983 GS 1100E
Last edit: 27 Nov 2013 08:27 by turboking.
- jp-15
27 Nov 2013 08:44 #614212
by jp-15
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
Replied by jp-15 on topic 33mm smoothbores on a 1015
Lets say it leaves room for improvement.
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
- CrazyDuck
- Thank you received: 6
27 Nov 2013 09:23 - 27 Nov 2013 09:26 #614216
by CrazyDuck
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
Replied by CrazyDuck on topic 33mm smoothbores on a 1015
I am going with a set of CR33's on my 1015 10.5:1 build. Ported head, bigger valves, GPZ cams, and Dyna2000 ignition.
Just remember that the stock head with those tiny intake runners can only flow so much. Someone had the flow charts for the different heads and carbs but I can't find it to save my life.
I spent way too much time evenly porting my head to match my carbs. I
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
Last edit: 27 Nov 2013 09:26 by CrazyDuck.
- jp-15
27 Nov 2013 13:18 #614235
by jp-15
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
I do plan on refurbishing the head with the top end rebuild. I may have psp clean up the ports while they're in there. Any ideas on what you're with for a initial starting point on the jetting Crazy Duck? I've only been playing with kz's for a couple years now and I've yet to mess with any carbs bigger than vm28's,
Thanks,
Joe
Thanks,
Joe
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
- hill
- 78 kz1000
27 Nov 2013 22:45 #614270
by hill
Replied by hill on topic 33mm smoothbores on a 1015
What size jet is in the carbs now.That would be a good starting point.Since your running more air than the 28mm carbs,you may have to go with a 25 main jet to start with.Make sure you ream out the intake manifolds to match the diameter of the head port.Those 33s should run great on that build,you'll just need a little more fuel for the extra air.
- mtkawboy
- Thank you received: 16
08 Jan 2014 15:59 #617805
by mtkawboy
Replied by mtkawboy on topic 33mm smoothbores on a 1015
I had 33s on my 1105 10.5-1, street ported 395lift 260 duration motor and they ran good wide open but never could get them to idle consistently. swapped them for a set of 29s and am much happier with them. Your results may vary
