Carb Hoses
- oredigger
26 Nov 2013 23:58 #614173
by oredigger
1980 KZ650-E1 LTD
Carb Hoses was created by oredigger
Hey all just a few quick questions as I am replacing my hoses.
According to this diagram: www.bikebandit.com/houseofmotorcycles/19...f/o/m150602#sch38455
Part 35- airflow hoses (about 5 inches), pretty self explanatory.
Part 33- going to petcock/fuel filter. I am going to keep these sizes the same. Correct me if I am wrong but is this a fuel filter in between my petcock and carbs? Should I look into replacing it?
43- now this is the one that is confusing me. I didn't take pics when I took it apart so I am not sure if this needs to be a certain length, also if the other end is connected to something...
Thanks
Attachment IMG_20131127_245351_309.jpg not found
Thanks
1980 KZ650-E1 LTD
- Thank you received: 2098
27 Nov 2013 06:41 - 27 Nov 2013 07:00 #614197
by Patton
Replied by Patton on topic Carb Hoses
Could try these:
35 -- both vent hoses exit to open air
33 -- fuel line
43 -- vacuum hose to petcock
Imo, a better in-line fuel filter:
In-line filter fits in the fuel line whereby fuel from the petcock flows through the filter before reaching the carbs.
33 -- fuel line
Attachment filterZ1.jpg not found
Last edit: 27 Nov 2013 07:00 by Patton.
27 Nov 2013 06:44 - 27 Nov 2013 07:01 #614199
by Patton
A precise length isn't critical on any of the mentioned hoses.
Should be fitted long enough to be free of any kinks.
Last edit: 27 Nov 2013 07:01 by Patton.
- oredigger
29 Nov 2013 22:45 #614429
by oredigger
1980 KZ650-E1 LTD
Replied by oredigger on topic Carb Hoses
Appreciate it Patton...got them all hooked up earlier no problem.
1980 KZ650-E1 LTD
- sbc1320
- Thank you received: 38
30 Nov 2013 07:03 #614442
by sbc1320
Have those on my bike and just bought 25'of new hose and replaced fuel lines.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Replied by sbc1320 on topic Carb Hoses
Patton wrote: Could try these:
33 -- fuel line
- Thank you received: 1656
30 Nov 2013 16:11 #614493
by martin_csr
Replied by martin_csr on topic Carb Hoses
The bike probably uses 5/16" fuel line, so get a fuel filter of the same size. The one in the photos here is 1/4" & the plastic is affected by gasoline w ethanol (not sure how the plastic holds up against gasoline without ethanol).
The next time I get a fuel filter, I'm going to get a metal bodied type w a sintered bronze element that can be cleaned or replaced. Russell is one brand.
Fuel filter note. Get one suitable for motorcycles or carbureted engines. Some from the auto parts stores don't flow enough fuel.
