83 KZ 440 LTD - Rebuilding the Carbs
- EastCoast
KZ 440 LTD (Bobber build)
- nickleo373
- Thank you received: 33
1981 KZ550C LTD
"If you ain't first, you're last"
- EastCoast
- EastCoast
- EastCoast
- Nebr_Rex
- Thank you received: 300
What filters are you planning on using?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- EastCoast
- Nebr_Rex
EastCoast wrote: No it has not been running since I have owned it. I have rebuilt carbs before and added jet kits to carbs when changing pipes but I dont know what set up i would need for this application or what would be best solution. i will try to get a picture of the back of the air box tonight but its the stock assembly that came on them i am sure. Anyway I wanted to use the single cone shaped red air pods by bike master or the grey cone shaped ones listed on ebay several places and are washable no oil designed.
Those wire mesh filters are junk. I am unfamiliar with red bike master filters, could you post a pic
both side and inside views please. Also use some mufflers. Without them you will draw unwanted
attention to youself ( the cops ) . And open pipes do not help performance with unless it is an all
out race machine, which you are a long way from being. Put some small cheap mufflers on and
order a jet kit from Sigma6 for free flowing exhaust and individual filters. You should use K&N or
Uni filters. I have not sees personally any other filters tat are worth a damn. Somebody else might
chime in here with a different filter suggestion.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- EastCoast
- Nebr_Rex
They make the PK series in 3 or 4 different sizes.
The inlet outside diameter of the carbs are about 2 1/8 in.
Their filters are straight, not tapered. Adding mufflers will
change jetting requirements. Stage 3 is for pods and open exhaust.
Stages 1 and 2 are for more stock type setups.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- EastCoast
