Smoothbore slow jet
- uglee
- New 2da game but Tru 2this thang!!!!!
11 Nov 2013 18:25 #612824
by uglee
Smoothbore slow jet was created by uglee
Ok guys I HAD a set of 29mm smoothies that I was gonna try and rebuild. During the tear down I found a stuck slow jet and tried to drill it out. Got it close and used a pick to dig out the remaining part of the brass jet. Screwed up the threads and now cant find a tap to fix it. Does anyone have any info or suggestions on how or if I can fix this problem without shipping my carbs off?
- Harvey1327
- Thank you received: 9
11 Nov 2013 20:18 #612837
by Harvey1327
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
Replied by Harvey1327 on topic Smoothbore slow jet
What ever you do don't send them to
www.motorcyclecarbs.com/
They take your money and/or parts and don't respond to any further contact.
Check them out on Ripoff Report.
They don't supply a phone no.
I wished I lived near them as they would not be around today
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
- peavylotus
- Movin on up
- Thank you received: 15
11 Nov 2013 23:49 #612843
by peavylotus
1980 KZ 1045 LTD Currently Workin' It Out
Replied by peavylotus on topic Smoothbore slow jet
You can helicoil it. you would have to find the size and thread pitch of your jet. A helicoil would allow you to tap a bigger diameter with the same thread pitch, tap new threads, insert helicoil, and install new stock jet. You would have to buy a helicoil kit and depending on the quality of the kit, may be about the same price as having a pro fix it. Never the less, still a DIY option.
- sbc1320
- Thank you received: 38
12 Nov 2013 05:34 #612852
by sbc1320
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Replied by sbc1320 on topic Smoothbore slow jet
If you could find a metal screw and lube it up then work it in and out you might have some luck.
- mtbspeedfreak
- Thank you received: 36
12 Nov 2013 07:44 #612866
by mtbspeedfreak
You could take that a small step further and use a Dremel to make a cut length-wise along the screw and deburr it, to create your own tap. I'd use a high quality steel screw.
2000 ZRX 1100
1976 KZ 900- Daily Driver
Replied by mtbspeedfreak on topic Smoothbore slow jet
sbc1320 wrote: If you could find a metal screw and lube it up then work it in and out you might have some luck.
2000 ZRX 1100
- uglee
12 Nov 2013 17:53 #612922
by uglee
Replied by uglee on topic Smoothbore slow jet
all good advice guys but this is the very small jet down in the carb body. local father and son hardware/auto parts store had nothing that small, so I know the big stores won't be able to help me.
- sbc1320
13 Nov 2013 03:54 #612942
by sbc1320
I have broken one before and used one of my left handed drill bits. It came right out.
- uglee
07 May 2014 21:52 #631762
by uglee
Well I tried remove it with a regular drill bit. Got a little too happy and now need to find a tap. Blew off a set of cabs from ebay(26mm) and will try them on the bike this weekend. they were pretty clean just had a few parts missing. Good thing I had an xtra set layin around,
- gd4now
- Denco where did you go?
- Thank you received: 443
08 May 2014 00:41 #631765
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Smoothbore slow jet
By slow jet I assume you are talking about the pilot jet. If that is the case then IIRC it is a Mikuni vm22/210 style pilot jet. It should be 14 mm in length and about 4mm in diameter (across the top of the jet) I do not remember the thread pitch for them but would think you could take one of the good ones you have and find a nut that would fit it. You would then have the size tap you need.
1977 KZ650 B1
The following user(s) said Thank You: BlackZ1R
- uglee
11 May 2014 23:18 #632156
by uglee
thanks for the info, will try locating parts soon.
