Starting my bike cold.....Starter fluid?
  • prizethedoubt
  • prizethedoubt's Avatar Topic Author
10 Nov 2013 15:58
#612727
Hey people
I had to buy a new starter motor. The starter motor works great. My bike was inactive for about 2 months and it is quite cold out. Full gas, full oil. Was thinking of using some starter fluid. I'm supposed to shoot this stuff in the air box under the seat? Or do I have to take off the side panels again? I own a KZ440 LTD 1982
Thanks
KZ 440 LTD 1982.
Re: Starting my bike cold.....Starter fluid?
10 Nov 2013 16:29 - 10 Nov 2013 16:29
#612728
Starter fluid is not necessary.
To start -
Fully charged battery
Choke on
Petcock on
Kill switch in "RUN"
Key on
Clutch lever pulled in
DO NOT TOUCH THE THROTTLE
Hit the starter button. Short bursts are better than one prolonged grind.
Last edit: 10 Nov 2013 16:29 by 650ed.
  • martin_csr
  • martin_csr's Avatar
10 Nov 2013 19:43 - 10 Nov 2013 19:44
#612739
And make sure the air filter is installed & the airbox cap n stuff is installed correctly.
Reference the diagrams at Kawasaki.com to make sure nothing is missing.
On some KZ440s it's possible to install the cap wrong: the test is to lift up on it - if it moves, it isn't installed correctly.
Note: do not pull up too hard as it could break.
I think there are two different airboxes for the 440s, but I do not know which one the test is for.
Also, make sure the airbox ducts are good & have a good seal. Same goes for the carb holders.
Last edit: 10 Nov 2013 19:44 by martin_csr.
  • prizethedoubt
10 Nov 2013 20:28
#612743
where do I spray the starter fluid exactly?
KZ 440 LTD 1982.
  • prizethedoubt
10 Nov 2013 20:30
#612744
I killed the battery trying to start it, so it is charging over night. I did have the air filter (that is under the seat) still off.
KZ 440 LTD 1982.
  • Haybus
  • Haybus's Avatar
  • Big Al
10 Nov 2013 21:10
#612749
Starter fluid is awesome for cleaning oil off things. As such if you use a lot while trying to start an engine it could be trouble. Best to verify spark and fuel, shouldn't need starting fluid if you've got spark and fuel. But if you must, you can spray it in the air box with the filter removed.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • KZB2 650
  • KZB2 650's Avatar
12 Nov 2013 10:09
#612880
Do you have a small space heater. I heated up my motor the first couple times after the rebuild for an hour or so and it was nice and warm. Also follow what 650ed said. In a real pinch (half dead battery) I've had my son and wife push me in 3 or 4th gear too. :laugh:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • bemoore
  • bemoore's Avatar
12 Nov 2013 11:06
#612885
I recommend limiting the use of starting fluid as much as possible. I have some, and I use it, but only as a last resort. I read once that it could temporarily dissolve the varnish on your valves, which would then re-solidify and could cause one or more valves to become complete stuck. I blew this off... until I did exactly that with a 289 Ford V8 engine. I wound up with two bent pushrods. With an overhead can setup like our KZ's, I don't know what would have to give way if a valve became stuck. Use starting fluid with great caution.
77 KZ650C1 w/Kerker 4-1
  • sbc1320
  • sbc1320's Avatar
12 Nov 2013 11:12
#612887
Personally I don't use starting fluid, but like stated use it sparingly. All that is needed is the vapor from it to start an engine. Spray a little in the air box and the fumes will get it started. I never use it on a gas engine. If they don't crank then I pull a plug and check for fire and see if it's wet with fuel. Too much will cause the cylinders to dry out and can cause one to start grinding and score the cylinders.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
