carb parts
- captscubaman
05 Nov 2013 11:36 #612167
by captscubaman
carb parts was created by captscubaman
Trying to find someone who has or stocks parts for 1973-74 Kawasaki Z1 28mm carb parts. . I need the dust shield as all the manuals call it. Listed on BikeBandits site as dust plate Part # 781582. Any help would be appreciated. There is one for each carburetor.
- etbike3135
- Thank you received: 50
05 Nov 2013 17:20 #612189
by etbike3135
1973 Kawasaki Z1
18 years in dragbikes
Replied by etbike3135 on topic carb parts
I have a few sets of parts carbs. Let me know what part that is. I think your referring to the round "freeze" plug type things up by the linkage?
1973 Kawasaki Z1
- sbc1320
- Thank you received: 38
05 Nov 2013 18:30 #612197
by sbc1320
Number 52 I believe it is:
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Replied by sbc1320 on topic carb parts
etbike3135 wrote: I have a few sets of parts carbs. Let me know what part that is. I think your referring to the round "freeze" plug type things up by the linkage?
- captscubaman
06 Nov 2013 04:18 #612215
by captscubaman
Replied by captscubaman on topic carb parts
Thanks etbike3135. BTW my name is Bob. I have just started rebuilding the 28 MM's. So only have one carb apart which has the broken part I am looking for. I will take the other 3 apart to see if any of them have the same part damaged. Like to do one set at a time for reference to reassemble. In the diagram its part # 52. It is made from a fibrous material. Guess it being 40 years old is why its broken. Let me know what you think. I don't think any set of carbs will have this part in good condition, Maybe best to fabricate this part from a sheet of nylon.
- captscubaman
06 Nov 2013 04:20 #612217
by captscubaman
Yes its part #52.
- captscubaman
07 Nov 2013 05:33 - 07 Nov 2013 05:38 #612298
by captscubaman
Good Morning, If you look at the diagram in the thread it shows #52 as being the dust sheild. No idea why its called a shield more like a gasket. Next item I found bad is one of the throttle plates. Its numbered E2.5. I guess someone grabbed it with a pair of pliers and marked it up so now it doesn't slide. Now I know why the throttle was sticking. Looking for this part also. You mentioned you might have a set of parts carbs. Let me know maybe we can work out something Thanks Bob
Last edit: 07 Nov 2013 05:38 by captscubaman.
