- Thank you received: 11
KZ turbo carb part identification?
- K.D. HART
04 Nov 2013 16:42 - 04 Nov 2013 17:14 #612086
by K.D. HART
KZ turbo carb part identification? was created by K.D. HART
This was screwed into the side of my Zenith carb where the choke plate attaches (if it had a choke) and I'm not sure what it is?
The long brass piece looks like a one way valve, maybe? It has "Clippard" stamped on it.
The brass 90 has a piece that can be screwed out. It looks kinda like a valve in a tire, but it's a jet.
Maybe this was to prime the bike for starting????
The carb goes to this bike.
www.kzrider.com/forum/11-projects/591120...-old-turbo-drag-bike
Last edit: 04 Nov 2013 17:14 by K.D. HART. Reason: added info
- Jeff.Saunders
05 Nov 2013 03:58 #612128
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic KZ turbo carb part identification?
where did it locate in the carb body?
It could be a couple of things.
- Many had a primitive primer that dumped raw fuel into the throat of the carb.
- The carb on my bike also modified for water/alcohol injection. There was a tank on the front of my bike that would be pressurized under boost via a hose from the manifold. The output from the tank was controlled by a small inline jet before being squirted into the carb.
Z1 Ent on Facebook,
- K.D. HART
05 Nov 2013 05:02 #612134
by K.D. HART
Replied by K.D. HART on topic KZ turbo carb part identification?
Jeff,
The first owner e-mailed me back last night and said, it was part of a water injection setup.
Thanks.
Thanks.
- Jeff.Saunders
05 Nov 2013 06:35 #612142
by Jeff.Saunders
Z1 Ent on Facebook,
I took the water/alcohol injection off my bike when I installed the Dyna 2000 ignition system. Having an electronic retard to help manage detonation is a lot easier than messing with the water injection.
Z1 Ent on Facebook,
- turboking
- Thank you received: 106
05 Nov 2013 15:04 - 05 Nov 2013 15:05 #612179
by turboking
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Replied by turboking on topic KZ turbo carb part identification?
you already found out ........ :dry: yes, it's a water injection jet with an anti siphon valve :blink: ........
1985 GS 1150E
1983 GS 1100E
Last edit: 05 Nov 2013 15:05 by turboking.
